ArcGIS Mobile SDK 10.1, Access violation reading location
3080
07-31-2015 10:54 AM
VincentThomas
Hello everyone,
I'm trying to debug a gigantic old .NET application based on ArcGIS for mobile SDK 10.1.1. When loading the GIS component of the application, about 1/5 times, I'm getting the error Access violation reading location xxx (see below). It comes at a random point in the code, so I'm suspecting a background thread running ESRIMobileCore.dll functions. Have you ever encountered issues with that library? Should my best guess would be to upgrade the ArcGIS Mobile SDK to a newer version? Thanks for your thoughts about how to debug that!
VincentThomas
I got it working. I was not assigning correctly the value of a ESRI.ArcGIS.Mobile.FeatureCaching.MobileCache object.
Friend Shared Sub SetService(ByRef service As ESRI.ArcGIS.Mobile.FeatureCaching.MobileCache)
Before
              service = mService
After
                Dim tempServiceCache As ESRI.ArcGIS.Mobile.FeatureCaching.MobileCache = New              ESRI.ArcGIS.Mobile.FeatureCaching.MobileCache(Common.GetGISMainCachePath())
                tempServiceCache.Open()
                service = tempServiceCache
To debug such error, one way is to comment out code until it doesn't break anymore and start from there, but since that error was a bit random, that wasn't an easy task.
Hope it helps someone!
Vincent
VincentThomas
Before
              service = mService
After
Vincent
