ArcGIS Mobile GPS Component does not work with specific GPS Model
4458
03-27-2015 06:27 AM
Joao_OlynthoAntunes_de_Oliveir
Hi everyone!
We have an application for Windows Mobile 5.0-6.5 that uses ArcGIS Mobile 10.1 for Windows Mobile. We are having an issue when using ArcGIS Mobile GPS Component with a specific GPS model. The application crashes probably on the event that is capturing the coordinates through the GPS output port.
The application works great with this model (Intermec CN3):
http://epsfiles.intermec.com/eps_files/eps_man/935-003.pdf
And it crashes when using this one (Intermec CN51):
Computador Móvel | CN51 Handheld Computer | Intermec CN51
Global Positioning System (with WAN Radio option) 12 channel Integrated GPS; Network independent autonomous mode; supports assisted operation via XTRA®, CP E911
•GPS dedicated AT commands
•Protocol: NMEA-0183 V2.3
•Tracking Sensitivity: better than -158 dBm
•GLONASS support
If we use an external GPS (Bluetooth GPS) with the CN51, the application works too. So, we are sure that the GPS is the problem.
