I have a point data for mine shafts that has depth below the surface. I would like to show this in a 3d map in ArcGIS Pro, but when I add the data and set the elevation it disappears. I have tried setting the above ground level to a negative number. It works for a bit and then moves back above ground.
Any help?
Thanks!
