Upadting the Basemap Url
2635
02-11-2013 08:53 PM
NigelDsouza
I have created an application with a base map and a Map service. I want to know if there through a simple Activity where the user enters a url of a new base map and on a onclick event of a "save " button the base map url gets updated with the new base map.
Also when the user exits and reopens the application the new base map gets loaded until he once again enters a new basemap url.
JeffBarrette
I'm an arcpy.mapping kind of guy, I'll embarrass myself if I try to answer a question on android.
I think there are much better forums for this specific question.  I found:
http://forums.arcgis.com/forums/139-ArcGIS-Runtime-SDK-for-Android
and here is a specific discussion on the topic:
http://forums.arcgis.com/threads/68683-switching-base-map-on-android
Sorry I can't be of further help,
Jeff
JeffBarrette
You would need to use something like Python add-ins in order to trap a click event.  You will also want to use arcpy.mapping UpdateLayer.  The problem is that you would need to pre-publish layer files for each possible basemap.  In this case, they wouldn't need to type in a URL but rather pick from a list of basemap names.
Jeff
NigelDsouza
Jeff
Hey Jeff,
Really appreciate the reply. I actually forgot to mention that this application is built on the android platform. So is there any way by which i can implement this on android?
Sorry for not specifying the platform.
Regards,
Nigel.
JeffBarrette
Jeff
NigelDsouza
Hey Jeff,
Your help is most appreciated. Thank you.
Regards,
Nigel.
