I'm working on a project where I'm trying to print out a series of maps that just follow a power line. The project will probably end up with about 150 11 x 17 inch maps. I've placed two data frames, one above the other (landscape) so I can save paper and space. I've used the strip grid generator for the data driven page to follow and used even/odd pages to drive the data frames. So far I've been doing what Donna Erskine suggested on this thread (which is talking about the same thing I'm trying to solve).Jeff Barrette's code suggestions inspired me to attempt to loop the one data frame code into two data frames. However, this attempt ended in abysmal failure. Every iteration seemed to confirm my suspicions that I know nothing about arcpy.mapping and data frames.Here's the code at the point where I gave up:# Experimental 2 dataframe pdf export import arcpy from arcpy import env document = r'C:\Users\Desktop\MapDocuments\Grids Tabloid v1.mxd' mxd = arcpy.mapping.MapDocument(document) dataframe = arcpy.mapping.ListDataFrames(mxd) lyr = arcpy.mapping.ListLayers(mxd, "*Grid*")[0] result = arcpy.GetCount_management(lyr) print 'Number of features in ' + str(lyr) + str(result) print '\nStarting to loop through grids...\n' i = 0 while i < result: print 'Printing PDF 0' + str(i) j = 0 for frame in dataframe: if j == 0: df = dataframe print 'Data frame0: ' + str(df) elif j == 1: df2 = dataframe print 'Data frame1: ' + str(df2) else: print 'Something\'s wrong' break lyr = arcpy.mapping.ListLayers(mxd, "*Grid*") print 'Grid layers: ' + str(lyr) rows = arcpy.SearchCursor(lyr.dataSource) k = 0 for row in rows: if k == i and j == 0: print 'in df arena' newDFExtent = row.getValue("Shape").extent df.extent = newDFExtent print df.rotation, print str() + ' has value from df 1!' elif k == i and j == 1: print 'in df2 arena' newDFExtent2 = row.getValue("Shape").extent df2.extent = newDFExtent2 print df2.rotation print str() + ' has value from df 2!' elif k <> i: print str() + ' is NO value...' k += 1 j += 1 arcpy.mapping.ExportToPDF(mxd, r'C:\Users\Desktop\PDFs\TestPDF ' \ + str(0) + str(i) + '.pdf') print 'Printed PDF 0' + str(i) + '\n' i += 1 del mxd
There's a lot of junk code in there so I could tell where the program was, and what it was or wasn't doing.The psuedo code goes like this:Find the number of grids in the strip map Identify the data frames Break out the layers that have 'grid' in their names Loop through the grid in the data frame and set the different extents and rotations for each data driven data frame Export the page to a PDF Go to the next page
The PDF output did not display different extents or rotations. I think from some of the other discussions that 10.1 might provide tools for this. I'll be done with this project by then.Any suggestions?
