The world from space projection
6699
06-29-2011 11:07 PM
by Anonymous User
Not applicable
Original User: alinard
I want to show the overview map using "The world from space" projection. I used it in older versions of ArcGIS without any problems (despite it was very slow), but in ArcGIS 10 I can't get the full extent of the world. It is somehow "cut off", more less along a great elliptic line (see attached images).
Any clues, what I am doing wrong? I try different lat/lon origin values, the problem remains the same.
Any help would be appreciated,
Jan
MelitaKennedy
Esri Notable Contributor
Hi Jan,
Is the problem in the main map or layout data frame, or in the overview window? I haven't yet been able to reproduce the problem in the data frame, and am still trying to get the overview window to work at all!
Melita
by Anonymous User
Not applicable
Hi Melita,
I think the problem is solved. After several tests I realized that the background data was already projected into "The world from space" projection (with certain lat/lon of center values) to speed up the display (see your reply: http://forums.esri.com/Thread.asp?c=93&f=984&t=281277).
This seems to clip all the data, which is not visible in this particular extent! This may be realized only when you change the lat / lon of center coordinates in the data frame.
In other words, the data projected into "The world from space" projection can only be used with the original lat / lon of center values.
Is it a proper behavior of the "Project" tool?
Regards,
Jan
MelitaKennedy
Hi Jan,
That's correct. When the software 'clips' features to a particular coordinate system, and saves them, it's permanent. We don't maintain the original feature and its clipped version in any permanent way.
I hadn't even thought about that reason!
Melita
