Storing Original Map properties
1337
02-22-2012 08:58 AM
NicholasMenard
Hello,
I'm trying to code (in VBA) a button to restore the layers status (visibility on or off) to when I first opened the mxd. It has to work for however many layers I have open. Any help would be much appreciated.
Thanks!
JeffBarrette
Do you have to do it in VBA?  You can do it with arcpy.mapping using the layer.visible property.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Layer/00s300000008000000/
Jeff
