Raster Classified Values Not The Same As Stretched Values, Why?
6577
09-04-2014 04:11 PM
GerryGabrisch
In my ArcMap project I have a grid. When displaying the grid with stretched values I see a range of 0 to (almost)1 like I would expect. See the first image below.  I can use the identify tool to select pixels in the grid and the identify returns values from 0 to (almost) 1 as expected.
If I try to classify these data I am only allowed to classify values from 0 to 0.47 (see the second image below).
Why is there a difference between the stretched range and the classified range?
ArcGIS 10.1.2
DanPatterson_Retired
Stretching the raster symbology doesn't change the underlying data, it simply is a visualization thing.   If you want to produce a raster with new values to reflect this, you are going to have to decide upon the type of raster reclassification you want to use.
GerryGabrisch
Dan,
Thanks for the reply.  I am not trying to change the underlying data, just symbolize it in a different. In the grid layer properties I can see that the min and max values are between 0 and 1.  My question is, when I try to symbolize those data by classes I see a different range of values.  Why?
AnnaScholl
probably because the max value is rounded. 0.9990011 is almost 1.
