Polygon circles from points
3539
04-23-2010 03:46 AM
ImranKlotz-Shiran
I need a tool that can creat polygon circle from points as follow:
1. center of the circle should be the X,Y coordinate value of the point
2. the diameter of the circle should be based on the Z value of the point
Your help will be much appriciated.
Imran
AntonioMoniz
Create layer point from X;Y and add Z field to the table or prepare a excel sheet with X;Y and Z (and other fields if you want) use "Make XY Event Layer" tool to create the new layer. After create a buffer from points using the field Z for
