Opening a schematic diagram in v.10 [C#]
1319
08-23-2012 06:16 AM
Hassene_Heridi
Hi everyone,
We're actually working on migrating 9.3 Schematics code into v.10 but we have some problems.
In the 9.3 version, we used to use the method "OpenDiagram" (from the INgDiagramType) to open a schematic diagram in the current map.
But impossible to find an equivalent to this method in the v.10.
Is anyone know which method to use instead? or if there's no equivalent, how can we try to open a diagram by code?
H.
RickAnderson
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/#/DisplayDiagram_Method/003t0000001...
You should use the ISchematicDisplayDiagramHelper.
You need first to have a handle to the ISchematicDataset, then you get the desired diagram class (the old diagram type).  From the class, you get the diagram and finally use the diagram helper to 'display' the diagram.
Dim pSchematicDiagramClass As ISchematicDiagramClass
  Dim pDiagramClassContainer As ISchematicDiagramClassContainer
  pDiagramClassContainer = m_pSchematicDataset
  pSchematicDiagramClass = pDiagramClassContainer.GetSchematicDiagramClass("INTERNAL_DIAGRAM")
Dim pDiagram As ISchematicDiagram
  pDiagram = pSchematicDiagramClass.SchematicDiagramByName(plant_name)
m_pDispDiagramHelper.DisplayDiagram(pDiagram, Nothing)
More information about migrating code:
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/d/000100000m29000000.h...
RickAnderson
Hassene_Heridi
Thank you for the answer.
