Label Expression
5449
8
08-31-2022 08:51 AM
lindajo04
If the [Situs_Unit] field is blank on the parcel layer I would like the # sign to not show on the map labeling.  Is there a way this can be accomplished?
This is my label expression for my parcel layer.  [Situs_Num] & " " & [Situs_St] & " # " & [Situs_Unit].  If the parcel has info in this field, [Stius_Unit], it looks like this:  103 Park #421.  If the parcel has no info in the unit field it looks like this:  124 Park #.  is there a way in the expression to remove the # sign if the field is blank?
Thank you,
Linda Jo
jcarlson
Any label expression language should allow you to use a conditional statement to build your label. It looks like you're using VBScript, is that right? I wouldn't know the specifics for that, if there's a particular reason you need VBScript, but it's fairly straightforward.
- Josh Carlson
Kendall County GIS
lindajo04
Thank you for your feedback. When I try the expression this is what I get:
[cid:[email protected]]
Any thoughts on what I did wrong?
KenBuja
MVP Esteemed Contributor
Can you reload those images?
KenBuja
You can build the label using VBScript this way
Function FindLabel ( [Situs_Num], [Situs_St], [Situs_Unit] )
  FindLabel = [Situs_Num] + " " + [Situs_St]
  if ( [Situs_Unit] <> null ) then
    FindLabel += " #" + [Situs_Unit]
  end if
End Function
lindajo04
Here is the response I get using the suggested code. Can you help me with what I did wrong?
[cid:[email protected]][cid:[email protected]]
KenBuja
Unfortunately, the images that you're uploading don't seem to be working properly.
lindajo04
Here are the images I have been trying to send you.
KenBuja
I had forgotten that VBScript doesn't have an incremental operator (+=).
    FindLabel = FindLabel + " #" + [Situs_Unit]
  end if
End Function
Is then field [Situs_Unit] a numeric field and does it have a null value or is it a string field with an empty string?
