Label Expression Question
2596
08-29-2016 03:41 PM
DEAF_PROBERT_68
Honored Contributor
I need to write a script within the Fire Protection Districts layer in the Label Manager to remove the label that  has all the labels for each polygon with their names like this: . Alamosa County Fire Protection District. What I would like is to remove the "Fire Protection District" because the map I am going to create is to be about  the Fire Protection Districts . They do not need to duplicate twice..
So here is the example I want to display just Alamosa County only and remove the Fire Protection District
How do I do that ?
AbdullahAnter
Honored Contributor
Write this expression
VB :            Replace([Field Name],"Fire Protection District","")
Python:       !%Field Name%!.replace("Fire Protection District","")
That will remove " Fire Protection District"  from label.
DanPatterson_Retired
what version of Arcmap?  that dialog looks like an older version or is that in maplex or something?
DEAF_PROBERT_68
Honored Contributor
no, ArcGIS Desktop 10.3.1 under Citrix.
AbdullahAnter
Honored Contributor
DEAF_PROBERT_68
Honored Contributor
Thank you. That worked !
moved to https://community.esri.com/community/gis/mapping?sr=search&searchId=9fb7db35-e446-4a4a-8480-7351c3cb...‌  try to direct mapping style questions there ... the GIS place is a cavernous pit where questions get dumped as a last resort
