How can you divide the world base map somewhere other then the International Dateline?
2573
07-01-2016 05:56 AM
DavidTurner
Instead of the map going from -180 deg to +180 deg, I'd like to split it at 0-360 deg.  My issue is that I can't do work that crosses the Pacific Ocean.
DanPatterson_Retired
This can 't be the easiest solution without coding, but oh well
https://www.arcgis.com/home/item.html?id=cff0eb2e740d4afd81525c9020673ec0
