How can I spaitially display features on my map without the different layers overlapping?
2254
6
03-03-2017 12:19 PM
MylesJohnson
The data is across 3 separate layers. When we turn on the layers there is overlapping of attributes from the 3 layers.
JimCousins
You are going to have to explain this better. Perhaps a screen capture, as well?
Regards,
Jim
MylesJohnson
This is a segment of our map where a cluster is formed.
How can I prevent the attributes from overlapping one another?
AbdullahAnter
Honored Contributor
Could you move this question to Mapping space.
AbdullahAnter
Honored Contributor
You need to read about  Maplex Label Engine.
Working with the Maplex Label Engine—Help | ArcGIS Desktop
ChrisDonohue__GISP
As  Abdullah Anter  mentioned, using Maplex instead of the Standard Label Engine is a good starting point.  By playing with the Maplex label settings, one can often resolve issues with overlapping labels.  However, it is not perfect, so if there is a need for a high quality map with well-placed labels, you may need to dump out the labels as annotation (either in the map or in a geodatabase), and then manually work on them.  If you go the annotation route, Maplex is still a good start - using it will reduce the amount of manually annotation work.
ArcGIS Help (10.2, 10.2.1, and 10.2.2) - Converting labels to annotation
Chris Donohue, GISP
JayantaPoddar
Try to adjust Label Weight Ranking of all the feature labels. Define same weight for all the labels to be displayed (higher than feature weights).
Think Location
