Exporting multiple layouts to multiple jpegs
1933
12-05-2011 05:36 AM
ThomasVincent1
Hello
I have got a map with 40 layers that need to be printed to JPG. They should all be printed independently. The scope does not change, the background does not change, only the selected layer is different.
How can I come by this problem. I started looking into arcpy but have seen that looping is more in modelbuilder.
Thx
JeffBarrette
Have you tried looking into the arcpy.mapping module?  There is an export to JPG function.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/ExportToJPEG/00s300000038000000/
You can very easily turn on and turn off layers, export, change dataframe extents, etc.
The following link is a great starting point:
http://blogs.esri.com/dev/blogs/arcgisdesktop/archive/2011/09/30/new-resources-available-for-getting...
Here is some very basic code:
mxd = arcpy.mapping.MapDocument("current")
#turn off all layers
for lyr in arcpy.mapping.ListLayers(mxd):
  lyr.visible = False
#turn one layer on at a time and export
  lyr.visible = True
  arcpy.mapping.ExportToJPG(mxd, "C:\\Temp\\"+ lyr.name + ".jpg")
  lyr.visible = False
del mxd
