display data of the fields, in sequence, automatically
3798
04-19-2016 09:04 AM
JillPlescher
Is there a way in ArcGIS online to display data by each field automatically?  Similiar to using the time interval app, but in this case,  Field 1 attributes display on map for a few seconds, then field 2 for a few seconds, etc.  I have water quality data.  The set -up of the table is each record is a sampling site and the field names are the date in which the sample was collected.  If there was a way to loop through the fields to show the data.....otherwise to use the time interval, do I need to create a table of one site and a field of the dates (with water quality data, fields = ecoli_1, ecoli_2) ?
WesMiller
Have you looked at Story Maps​?
