Data Frame Properties - Clip to Shape - Exported PDF isn't correct
2688
08-23-2012 11:34 AM
MichaelRivera
On the attached PDF, I'm clipping a density raster to a county polygon.  The layout looks great, but when exported to a PDF this is the result.  A bar on the top and bottom of the pdf of that raster that would appear had it not been clipped.
I'm using ArcMap 10.1 Advanced.
Attached is a screenshot of the Layout, and the PDF.
by Anonymous User
Not applicable
Original User: mrivera
I found out what solved the problem.
I was clipping to the shape of the county and then excluding the County layer.  If I didn't exclude the county layer (in other words, allow the county layer to be clipped) then there was no issue.
MichaelRivera
Glad to see this is going to be fixed in Service Pack 1 of 10.1
NIM066834 - Data frame clipping does not clip the top and bottom bands of raster layers on output when at least one layer has df clipping layer exclusion turned on.
