Converting GDB to SQL, drawing error
3270
07-25-2011 04:08 AM
ScottSnider
I'm working on converting the template gdb to our sql server.  I had no problem tranfering the schema and data via the XML conversion, but I do have a problem with the RoadCenterline layer in the template mxd.
The error I get is in the ArcMap Drawing Errors window:
"Underlying DBMS error [Micorsoft SQL Server Native Client 10.0:'CHAR_LENGTH' is not a recognized built-in function name.]
[-feature name-]
Any thoughts?  I've looked at the schema and all of the attributes for the RoadCenterlines layer and cannot find anything that says 'CHAR_LENGTH' anywhere.  I'm assuming it has to do with the difference between the File GDB and the SQL GDB.  The roads are still drawing and labeling, so I do not even know what is really going wrong with this error.
Scott
KateBorland
CHAR_LENGTH is a SQL Function that is being used in the SQL query for most of the RoadCenterline label classes that include road shields.  These label classes and their associated SQL queries are:
Interstate_Shield - "RoadClass"  IN (1 , 2) AND "HIGHWAYTYPE" = 1 AND CHAR_LENGTH ( "HWY" ) < 3
US Highway_Shield - "RoadClass"  IN (1 , 2  ) AND "HIGHWAYTYPE" = 2 AND CHAR_LENGTH ( "HWY" ) < 3
State Highway_Shield - "RoadClass"  IN (1 , 2  ) AND "HIGHWAYTYPE" = 3  AND CHAR_LENGTH ( "HWY" ) < 3
Interstate_WideShield - "RoadClass"  IN (1 , 2) AND "HIGHWAYTYPE" = 1 AND CHAR_LENGTH ( "HWY" ) >= 3
US Highway_WideShield - "RoadClass"  IN (1 , 2) AND "HIGHWAYTYPE" = 2 AND CHAR_LENGTH ( "HWY" ) >= 3
State Highway_WideShield - "RoadClass"  IN (1 , 2) AND "HIGHWAYTYPE" = 3 AND CHAR_LENGTH ( "HWY" ) >= 3
These queries control the shield symbol that will be used for various route numbers.  Any route numbers that are less than 3 characters will use the smaller shields and any that are 3 or more characters will use the wide shields.
You can find the Label classes and SQL queries in the Label properties tab.
Let me know if you need any other information.
-Kate
ScottSnider
Perfect, thank you very much!!!!
For documentation's sake:
I went through each map level and checked the SQL Queries for all of the Classes w/ the name "Shield" in them.  I Changed the "CHAR_LENGTH" statement to "LEN" and that fixed the problem.  Now I see that I was missing highway shields!
SeikiAlice
[-feature name-]
Scott
Thanks you for the post.
