Attribute
3382
14
02-05-2018 11:44 AM
DavidSpivey
ArcMap
Have attributes from 1 point that display on map. Can't select it.
Map showing Attribute
Turn off all layers and Attribute text remains on screen. Turning of All Layers still displays attribute
DavidSpivey
Actually that did fixed it… It has not been selectable, but I tried one more time and it let me delete it!
Don’t know how it got there or why I couldn’t select it before…
User issue I’m sure!!
Thanks for the help!
DanPatterson_Retired
That is strange, especially if you tried the moving layers to a new dataframe and they came with it
DavidSpivey
Actually it just got fixed it… It has not been selectable, but I tried one more time and it let me delete it!
I realize that I was trying to select it in editor mode. However the Item was not in the the SDE I was editing!
Duh....
Thanks for suggestions!
Every suggestion is a learning experience!
The missing bits... SDE and edit mode ...
DavidSpivey
Yeah, I never put the 2 together… But working through everbody’s suggestions got me there!!
