This is my workflow:
And there is no difference if I use SHIFT button to keep selection or if I change "Interactive selection method" to "Add to current selection".
And this occurs also on different machine from my usual desktop work.
Please fix this BUG as soon as possible! It's impossible to work in this way!
Thank you for your attention
Stefano
Solved after installation of this patch, despite description does not correspond apparently to the issue in question:
ArcGIS Desktop Buffer Wizard Patch
Stefano
Stefano,
What version of ArcMap are you running? What type of geometry is your layer (point, line, polygon)? What kind of layer is it (shapefile, geodatabase feature class, enterprise feature class, etc.)?
I'm sorry...last version of ArcGIS Desktop 10.6.1, with any kind of geometry (point, line, polygon) from a File Geodatabase
I've also delete "Normal.mxt"...same result.
Is it possible to use a shapefile to test a different data-type? Or even a different geodatabase? I'm just thinking of how to single out the issue.
I'm experimenting this on different Geodatabase...and also with Shapefile
Maybe a "regional" bug, affecting only ArcMap on non US-platform?
Stefano,
The data which is stored in the feature class in the file geodatabase is it located locally on your machine or is it on a shared network path?
~Shan
And you mentioned that the same issue occurs when you are using a different machine as well?
Can you test the exact same workflow with the Template Data available in C:\Program Files (x86)\ArcGIS\Desktop10.6\TemplateData\
This is a sample data that gets created when you install arcgis desktop on your machine. This will help us out to verify if the issue us specific to the database that you are using.
~Shan
Same worflow...same result.
Tried with "City", "rivers", "continent".
Load on map:
I made a video...
Cheers
Stefano
