Adjust color ramp raster tif
8304
14
05-08-2017 03:51 AM
AnneTrampe
Hello everyone,
I am trying to reproduce the same characteristics of a raster tif than the same attached in the picture.
I have a raster tif with different value. I already excluded all values above 1000 as they are land area.
I now want to have a descrete color ramp or stretched color ramp, but want to adjust it with certain values/breaks where the colour changes. it should look like this:
But I just achieved this:
AnneTrampe
But I can not change the values. I type something in and it switches back to the value before
PanGIS
Start from the bottom.
Probably it's because the values overlap.
AnneTrampe
Ah, I found the mistake: You need to change the values starting from minimum. If you do maximum first it is not working. Thank you very much for your help
PanGIS
Glad it helped.
GünterDörffel
In case you check back: If you need this more than once ... think about creating a function template using the raster functions of "remap" and "attribute table", story it as a rft.xml that you can easily edit and reuse - PLUS your data will have a proper legend in the TOC then. Make sure you honor the valuable hints on compression and resampling in the attribute table function description. Feel free to ask if things are unclear. Provide a small sample image if needed. Regards Guenter
