Oracle eGDB SDE Repo Upgrade Using Oracle Restore Point
3275
07-07-2022 12:14 PM
MarceloMarques
 _________________________________________________________________________________________________
Oracle Enterprise Geodatabase SDE Repository Upgrade using an
Oracle Restore Point to Rollback the changes in case of problems.
Download PDF Version
1. ArcGIS Documentation - Before you upgrade
Read the ArcGIS documentation before you attempt to upgrade the geodatabase repository.
Upgrade a Geodatabase in Oracle - Before you Upgrade
Read the ArcGIS requirements for Oracle to confirm that Esri supports the Oracle and ArcGIS version combination you want to use.
2. Oracle Archiving and Oracle Flashback
a. Oracle Archiving must be enabled
b. Oracle Flashkback must be enabled
c. Oracle RMAN Incremental Level 0 ( Full ) Backup must be created
d. Oracle RMAN Incremental Level 1 ( Incremental ) Backup must be created
e. Oracle RMAN archivelog Backup must be created
f. Pluggable Database Logging must be enabled
sqlplus /nolog
SQL> connect /as sysdba
SQL> ALTER SESSION SET CONTAINER = cdb$root;
SQL> SHOW CON_NAME
SQL> show parameter db_recovery_file_dest
NAME TYPE VALUE
db_recovery_file_dest string +FRA
db_recovery_file_dest_size big integer 100G
SQL> show parameter undo_retention
NAME TYPE VALUE
undo_retention integer 86400                 <== 24 hours
( note: the undo tablespace size needs to be large )
SQL> show parameter db_flashback_retention_target
NAME TYPE VALUE
db_flashback_retention_target integer 1440               <== default in minutes = 24hours
SQL> show parameter log_archive_
NAME TYPE VALUE
log_archive_dest_1 string LOCATION=USE_DB_RECOVERY_FILE_DEST
log_archive_format string mcs1_log_%r_%t_%s.arc
SQL> archive log list
Database log mode Archive Mode
Automatic archival Enabled
Archive destination USE_DB_RECOVERY_FILE_DEST
Oldest online log sequence 3739
Next log sequence to archive 3741
Current log sequence 3741
SQL> select name,open_mode,log_mode,flashback_on from v$database;
NAME OPEN_MODE LOG_MODE FLASHBACK_ON
MCS1 READ WRITE ARCHIVELOG YES
--Pluggable Database Logging must be enabled
SQL> SELECT * FROM dba_pdbs ORDER BY pdb_name;
--if logging is disabled
SQL> SHOW CON_NAME
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> CLOSE IMMEDIATE;
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> OPEN RESTRICTED;
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> LOGGING;
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> OPEN READ WRITE;
SQL> SELECT * FROM v$pdbs ORDER BY name;
3. Create the Restore Point
sqlplus /nolog
SQL> ALTER SESSION SET CONTAINER = <PDB_NAME>;
SQL> SHOW CON_NAME
SQL> CREATE RESTORE POINT before_gdb_upgrade GUARANTEE FLASHBACK DATABASE;
SQL> SELECT * FROM V$RESTORE_POINT;
4. Check Invalid Objects
SQL> SHOW CON_NAME
SQL>  SELECT * FROM DBA_OBJECTS
WHERE STATUS!= 'VALID'
ORDER BY OWNER, OBJECT_TYPE, OBJECT_NAME;
5. Privileges Required for Geodatabase Upgrade
SQL> SHOW CON_NAME
SQL> CREATE ROLE GIS_SDE_MASTER;
SQL> GRANT CREATE SESSION,
CREATE TABLE,
CREATE VIEW,
CREATE PROCEDURE,
CREATE SEQUENCE,
CREATE TRIGGER,
CREATE TYPE,
CREATE INDEXTYPE,
CREATE LIBRARY,
CREATE PUBLIC SYNONYM,
DROP PUBLIC SYNONYM,
ADMINISTER DATABASE TRIGGER,
CREATE OPERATOR
TO GIS_SDE_MASTER;
SQL> GRANT SELECT_CATALOG_ROLE TO SDE;
SQL> GRANT SELECT_CATALOG_ROLE TO GIS_SDE_MASTER;
SQL> GRANT EXECUTE ON DBMS_CRYPTO TO GIS_SDE_MASTER;
SQL> GRANT GIS_SDE_MASTER TO SDE;
--Execute privileges on required Oracle builtin package DBMS_CRYPTO
--must be granted directly to the SDE DBA user,
--granting them to a ROLE with execute access is insufficient.
SQL> GRANT EXECUTE ON DBMS_CRYPTO TO SDE;
SQL> GRANT EXECUTE ON DBMS_PIPE TO SDE;
SQL> CREATE ROLE GIS_SDE_MASTER_UPGRADE;
CREATE TABLE,
CREATE PROCEDURE,
CREATE SEQUENCE,
CREATE TRIGGER,
CREATE TYPE,
CREATE LIBRARY,
ALTER ANY INDEX,
CREATE ANY INDEX,
DROP ANY INDEX,
CREATE ANY TRIGGER,
CREATE ANY VIEW,
DROP ANY VIEW,
SELECT ANY TABLE,
CREATE OPERATOR,
CREATE INDEXTYPE
TO GIS_SDE_MASTER_UPGRADE;
SQL> GRANT GIS_SDE_MASTER_UPGRADE TO SDE;
For more information read - Privileges required for geodatabase creation or upgrade
6. Active Connections
Make sure all user connections are closed.
Tip: ArcGIS Pro > Right Click Geodatabase Connection File for the "sde" user > Properties > Database Properties > Connections > Show connected user and locks...
This includes ArcMap, ArcCatalog and ArcGIS Pro.
You will need to ask users to close the applications and/or have the Oracle Database Administrator to kill the user connections.
Also, stop all ArcGIS Server Services that connect to the Enterprise Geodatabase.
Tip: when you open ArcCatalog or ArcGIS Pro to perform the Geodatabase Repository Upgrade make sure to click only on the Geodatabase Connection File for the "sde" user, if you click on any other connection file (e.g. data owner user, editor/viewer users) then you create a geodatabase lock that will prevent the upgrade to proceed, you must close ArcCatalog or ArcGIS Pro and re-open, only the "sde" user can perform the upgrade.
After all users and services connections are closed  you can disable geodatabase connections to prevent any new connections to the geodatabase, of course only the "sde" user is allowed to connect.
Tip: ArcGIS Pro > Right Click Geodatabase Connection File for the "sde" user > Properties > Database Properties > Connections > turn off "Geodatabase is accepting connections" > Click Ok
7. Upgrade Geodatabase Repository
Follow the steps described in the documentation to upgrade the geodatabase repository.
Upgrade a geodatabase in Oracle
Use the Upgrade Geodatabase Geoprocessing tool
Upgrade Geodatabase (Data Management)
Right Click Geodatabase Connection File for the "sde" user > Properties > Database Properties > Upgrade Status
Tip: if you turned off the option "Geodatabase is accepting connections", then after the upgrade the option is turned on automatically
ArcGIS Pro > Right Click Geodatabase Connection File for the "sde" user > Properties > Database Properties > Connections > "Geodatabase is accepting connections" >
!!! Note: If there are any problems with the geodatabase repository upgrade and you want to roll back the changes then see below "Appendix - Restore using flashback database".
8. Check Invalid Objects
SQL> SHOW CON_NAME
9. Recompile Invalid Objects
Recompile any invalid objects in the SDE user and data owner users, then check again for invalid objects.
SQL> SHOW CON_NAME
SQL> EXEC dbms_utility.compile_schema( 'SDE', compile_all => FALSE );
SQL> EXEC dbms_utility.compile_schema( 'GIS', compile_all => FALSE );
10. Check Invalid Indexes
SQL> SHOW CON_NAME
SQL> SELECT * FROM ALL_INDEXES d WHERE d.status NOT IN ('VALID','N/A');
11. Revoke Privileges Required for Geodatabase Upgrade
SQL> SHOW CON_NAME
SQL> REVOKE GIS_SDE_MASTER_UPGRADE FROM SDE;
Repeat the steps 8, 9, 10 above to check Invalid Objects and Invalid Indexes
12. Update the ST_GEOMETRY library
Copy the new version of the ST_GEOMETRY library to the Oracle Database Server.
For more information read - Configure extproc to access ST_Geometry in Oracle
a. Update the sde.st_shapelib library if the path changed.
SQL> SHOW CON_NAME
SQL> CREATE OR REPLACE LIBRARY sde.st_shapelib
AS '/orahome1/dbbase1/esrilibs/pro_30/libst_shapelib.so';
b. Check the library
SELECT * FROM ALL_LIBRARIES WHERE OWNER = 'SDE' ORDER BY OWNER, LIBRARY_NAME;
c. Check Invalid Objects
d. Recompile Invalid Objects and then check again for invalid objects.
e. Validate the extproc configuration
Note: connect as the sde user or as the data owner user !!!
SQL> SELECT sde.st_geometry(1,1,1,1,0) FROM dual;
SQL> SELECT sde.st_geometry('point (1 1)', 0) FROM dual;
SQL> SELECT sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) FROM dual;
13. Check Invalid Objects
SQL> SHOW CON_NAME
14. Check Invalid Indexes
SQL> SHOW CON_NAME
15. Gather new Statistics
SQL> SHOW CON_NAME
SQL> BEGIN
SYS.DBMS_STATS.GATHER_SCHEMA_STATS (
OwnName => 'SDE'
,Granularity => 'ALL'
,Options => 'GATHER'
,Gather_Temp => FALSE
,Degree => 4
,Cascade => TRUE
,No_Invalidate => FALSE);
END;
SQL> BEGIN
OwnName => 'GIS'
,Degree => 4
,Cascade => TRUE
END;
16. Drop the Restore Point
SQL> SHOW CON_NAME
SQL> DROP RESTORE POINT before_gdb_upgrade;
17. Execute RMAN Backup
Execute a RMAN Incremental Level 0 ( Full ) Backup and/or RMAN Incremental Level 1 ( Incremental ) Backup and also execute a RMAN archivelog backup to free space in the FRA - Fast Recovery Area.
sqlplus /nolog
SQL> SHOW CON_NAME
SQL> SELECT pdb_name, status FROM dba_pdbs ORDER BY pdb_name;
SQL> SELECT name, open_mode, restricted FROM v$pdbs ORDER BY name;
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> CLOSE;
SQL> FLASHBACK PLUGGABLE DATABASE <PDB_NAME> TO RESTORE POINT before_gdb_upgrade;
SQL> ALTER PLUGGABLE DATABASE <PDB_NAME> OPEN RESETLOGS;
FAQ - Frequent Asked Questions
1. Can I upgrade the Geodatabase Repository if the Geodatabase has Traditional Versions or Branch Versions?
Answer: Yes, you can. There is no problem to upgrade.
2. Is necessary to Reconcile and Post the Geodatabase Versions before the Geodatabase Repository Upgrade?
Answer: No, it is not necessary.
Contributors
About the Author
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | 33 years' experience | www.linkedin.com/in/mmarquesbr | | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career." | | " a successful Enterprise ArcGIS application deployment starts with a strong physical database design and best database administration practices" | | “The mountains are calling and I must go.” – John Muir | | " I do not fear computers. I fear the lack of them." - Isaac Asimov |
