How to label feature by using part of the field values
5065
10-10-2019 12:18 AM
Liliaaaaaa
Hi guys, I have to label all the cables by using all the highlighted numbers from the 'Identifer' field as screenshot. I don't want to create another filed so would like this to be done in label expression? Any fabulous suggestion?
(the number is always start in the 21st word, but ends either the 22nd or 23rd, for example, if the value is "4200-SUB-LUK014-3H1-2", then I just want to label the feature as "2"; if  the value is "4200-SUB-LUK014-3H1-36", then I will want to label the feature as "36".)
Liliaaaaaa
Thank you Ken, I have also figure in Python, just write down if anyone needs it.
  1. After opening the label Expression window in the label tab of ArcMap, please tick Advanced in the expression and choose Python in the Parser.
  1. Please paste the following script into the Expression window:
def FindLabel ([Identifier]):
    s = [Identifier]
    return s[20:]
  1. The [Name] field is the column that you want to label with.
  1. The [20:] in the script means choose the string start from 21st and to the last character of the cell value. If you want to start from another location, just change the “20” in the script.
KenBuja
MVP Esteemed Contributor
Use the Split function
Function FindLabel ( [Identifier] )
  dim values
  values = Split( [Identifier] ,"-")
  FindLabel = values(UBound(values)) 'This returns the last value. If it's always the same format, just use values(4)
End Function
Liliaaaaaa
    s = [Identifier]
    return s[20:]
KenBuja
You should mark your answer as correct so that others with this same question can easily find it.
