Select Widget - only show visible layers
724
01-27-2021 11:25 AM
Status: Implemented
MarlboroughDistrict_Council
It would be easier for the user if in the Select widget, it either only displayed the layers that are actually turned on in the map, or if there was an tick box available that would limit the layers shown to be those that are turned on in the map.
In a map with hundreds of layers, it can be very time consuming to find the relevant layers to turn on/off or find after doing a selection.
2 Comments
LaurenMcArtney
Hi @MarlboroughDistrict_Council we will be reviewing the select widget as a part of the build for next reelase. We will be taking this into consideration alongside the other great enhancements you and other folks have sent through. I will ensure this is feed into the select review for you.
Aravindh_Rajendran
This appears to be implemented. I.e. Layers only appear when they are turned on through Layer list widget.
