Campus Place Locator - Not showing Floors/Buldings
1042
08-08-2018 08:52 AM
Luiz_AmadeuCoutinho
Hi guys
I´m trying to use Campus Place Locator with my data. I did everything from the Tutorial but the Building Filter never work and Floor Numbers too.
Here my feature service Hosted/BuildingInterior (FeatureServer)
And attached my config.js
Luiz_AmadeuCoutinho
Anyone?  😞
LindsayThomas
Hello Luiz,
I looked at your config.js and services.
It looks like the service has lowercase field names (Layer: Building (ID: 3)   for example buildingid.
But, the configuration file is using uppercase fields for example BUILDINGID.
I think making the fieldname case match in the config.js should fix the issue
-Lindsay
Luiz_AmadeuCoutinho
Hi Lindsay
Yes I saw the difference and it´s weird. I´m using the geodatabase from Campus Place Locator and never changed the field names to Lowcase but after publish everything was changed.
I´ll try to edit my config.js now to match the field names.
Thank you.
I´ll back with news in few minutes. 🙂
Luiz_AmadeuCoutinho
It works perfectly. Thank you so much
