Show multiple mmpk using the native Kotlin SDK
876
08-12-2024 01:32 PM
TiagoSantos2024
Does anyone know if it is possible to load/show multiple mmpks files at the same time when rendering the offline map using either the Kotlin or Swift ArcGis SDKs?
We have a big map and is splitted in multiple mmpks (each mmpk has a different area from the map with little or no overlaps between them) and I would like to show the user the corresponding mmpk according to the position in the map (meaning that when I move the focus in the map, it should show other mmpk according to that coordinates and, if needed, maps from different mmpks in the screen)...
Tags (3)
RamaChintapalli
That is not possible with the current SDK. You can read multiple mmpks and keep the collection of all maps but can assign only a single instance of map to the Mapview at a time and switch between them (if necessary).
Rama
