For-loop range must have an 'iterator()' method when making legend in Kotlin
3135
08-23-2023 02:36 PM
klebercj
private fun showLegendDialog() {
val dialogView = LayoutInflater.from(this).inflate(R.layout.legend_dialog, null)
val builder = AlertDialog.Builder(this)
.setTitle("Legend")
.setView(dialogView)
.setPositiveButton("Close") { dialog, _ -> dialog.dismiss() }
val dialog = builder.create()
dialog.show()
val legendLayout: LinearLayout = dialogView.findViewById(R.id.legendLayout)
val mapImageLayer = mapView.map?.operationalLayers?.get(0) as? ArcGISMapImageLayer
mapImageLayer?.let {
CoroutineScope(Dispatchers.Main).launch {
for (sublayer in it.mapImageSublayers) {
val legenddata = sublayer.fetchLegendInfos()
for (legendInfo in legenddata) { // error is here
val legendImageView = ImageView(this@MainActivity)
val symbol = legendInfo.symbol
if (symbol != null) {
// Set the symbol directly to the ImageView
legendImageView.setImageDrawable(symbol.toDrawable(this@MainActivity))
legendLayout.addView(legendImageView)
val legendName = legendInfo.name
if (legendName.isNotEmpty()) {
val legendNameTextView = TextView(this@MainActivity)
legendNameTextView.text = legendName
legendLayout.addView(legendNameTextView)
Error is at for (legendInfo in legenddata) Android Studio keeps throwing an error stating the "For-loop range must have an 'iterator()' method"
SorenRoth
fetchLegendInfos() is a suspending function and all suspending functions in the ArcGIS Maps SDK for Kotlin return a Result type. In this case the result wraps a List<LegendInfo>.
One way to get the list from the result is to write the following
val legenddata = sublayer.fetchLegendInfos().getOrThrow()
SorenRoth
klebercj
This worked thank you
