Programmed Instruction
981
04-13-2020 02:25 PM
TomBaker
Programmed instruction (PI) has been around for decades – probably 50 years.  It’s designed to provide bite-sized chunks of information that the reader must read and then answer a short question about.  Ideally, if the reader is correct they progress and if wrong, some mitigating instruction is applied.  The example with Survey123 checks the major pedagogical boxes of PI.
Keep in mind, this is not intended to be an assessment.   https://arcg.is/CGyv
