Not able to add ArcGISDynamicMapServiceLayer in Arc
5715
03-20-2013 10:27 PM
RavindraSingh
I am creating a very simple program to add dynamic map service from ArcGISOnline.
I am getting following error when i rung the application:
Can any one help in this. is there any setting which is required to be done, in terms of proxy or something?
Java version : 1.6.0_27 (Sun Microsystems Inc.) x86
Rendering engine : DirectX
org.apache.http.conn.HttpHostConnectException: Connection to http://sampleserver1.arcgisonline.com refused
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:127)
at org.apache.http.impl.conn.AbstractPoolEntry.open(AbstractPoolEntry.java:147)
at org.apache.http.impl.conn.AbstractPooledConnAdapter.open(AbstractPooledConnAdapter.java:108)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:415)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:731)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
at com.esri.core.internal.io.handler.l.a(Unknown Source)
at com.esri.core.internal.tasks.a.p.a(Unknown Source)
at com.esri.core.internal.tasks.a.p.execute(Unknown Source)
at com.esri.map.Layer.loadServiceInfo(Unknown Source)
at com.esri.map.Layer.getMapServerInfo(Unknown Source)
at com.esri.map.ArcGISDynamicMapServiceLayer$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.net.ConnectException: Connection timed out: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:123)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:123)
... 20 more
EricBader
Honored Contributor
It appears that the service may be secured? You may need to pass the user credentials in when creating the layer. Maybe?
EricBader
Honored Contributor
RavindraSingh
The service is not secured::
ArcGISTiledMapServiceLayer tiledLayer = new ArcGISTiledMapServiceLayer(
                "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        //LayerList layers = map.getLayers();
       // layers.add(tiledLayer);
        map.getLayers().add(tiledLayer);
even this is also not being displayed... i am getting same error.
SachinKanaujia
If you are behind a proxy (authenticated or otherwise) then you need to configure the proxy details to access external servers (services). The ESRI Proxy code is broken so its recommended you set up the system properties to do the same.
            String username = "username";
            String password = "password";
            System.setProperty("http.proxySet", "true");
            System.setProperty("http.proxyType", "4");
            System.setProperty("http.proxyHost", "proxy server");
            System.setProperty("http.proxyPort", "proxy port");
            System.setProperty("http.proxyUser", username);
            System.setProperty("http.proxyPassword", password);
            System.setProperty("http.nonProxyHosts", "127.0.0.1");   // to allow local server
Adjust the code accordingly
EdgarCanul
Great! Thanks.
I just have one question. May be the proxy parameters are not correct. How can you catch this connection exception (org.apache.http.conn.HttpHostConnectException) since it's not thrown by JMap class itself. I need to catch this error and take suitable actions or an appropriate warning message about the proxy parameters correctness.
I tried:
MapOptions mapOptions = new MapOptions(MapType.STREETS, 24.43261, -102.92041, 4);
try{
JMap jMap = new JMap(mapOptions);
  jMap.setWrapAroundEnabled(true);
catch(org.apache.http.conn.HttpHostConnectException){
   // Handle error connection due to incorrect proxy parameters
But, of course, the compiler claims "Out of Reach try catch clause"
EricBader
Honored Contributor
First of all, good "catch". by the way.
What happens when you try to catch a general Exception?
This is what works for me. Surround your layer definition code with a try/catch for Exception, instead of a specific one. I know it sounds improper, but this may get you farther along, hopefully?
