Are MapTips Supported in GraphicsLayer and are they working in FXMap in the beta?
2224
10-27-2015 05:18 AM
EricHolsinger
We're working with a GraphicsLayer.  After adding attributes to a graphic and creating a corresponding LinkedHashMap, no worky, see code below:
//add a symbol and attributes, create the graphic
GraphicsLayer graphicsLayer = new GraphicsLayer();
TextSymbol textSymbol = new TextSymbol(10, "The symbol's contructor text!", Color.BLUE);
Map<String, Object> attributes = new HashMap<String, Object>();
attributes.put("UserId", "UserId");  //and other fields
Graphic graphic = new Graphic(point, textSymbol, attributes);
//after layer is initialized, from layerInitializeComplete on graphicslayer, add MapTips, tried this 6 Ways From Sun'dy, no worky:
LinkedHashMap<String, String> displayFields = new LinkedHashMap<String, String>();
displayFields.put("UserId", "UserId");  //and other fields if needed
MapTip mapTip = new MapTip(displayFields);
mapTip.setEnabled(true);
graphicsLayer.setMapTip(mapTip);
I figure this is not supported on GraphicsLayer, correct me if I'm wrong?
Also, if this is supported on GraphicsLayer, how is it added in FXMap?
final InfoPopupOverlay infoPopupOverlay = new InfoPopupOverlay();
        infoPopupOverlay.setPopupTitle("Building Data");
        infoPopupOverlay.setItemTitle("Extent of damage: {typdamage}");
map.??
Same answer?  Not supported in GraphicsLayer or FXMap viewer, right?
Thanks in advance,
The Other Eric
EricBader
Honored Contributor
Hi Eric,
I've used your code above with point graphics in a graphicslayer and I can get it to work. However, it looks like you are trying to get it to work with graphic TextSymbols. This isn't supposed to work, I don't believe.
As for the Beta of JavaFX, you are right. At Quartz we will fully support JavaFX and this workflow.
