LocalMapService internal exception
2324
08-05-2016 04:15 PM
MichaelKnight
Hi Guys,
I have been encountering some serious issues with the LocalMapService class in the 10.1.1 API for Java. I get an internal socket exception being thrown  within the ESRI code when I stop them. Has any one else experienced this?
Code Sample:
m_localMapService = new LocalMapService(BLANK_MPK_PATH);
m_localMapService.setEnableDynamicLayers(true);
m_localMapService.start();
m_localMapService.stop(); // Internal exception thrown
Exception:
java.net.SocketException: Software caused connection abort: recv failed
  at java.net.SocketInputStream.socketRead0(Native Method)
  at java.net.SocketInputStream.socketRead(Unknown Source)
  at java.net.SocketInputStream.read(Unknown Source)
  at org.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:130)
  at org.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:127)
  at org.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:233)
  at org.apache.http.impl.conn.DefaultResponseParser.parseHead(DefaultResponseParser.java:98)
  at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:210)
  at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:271)
  at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:227)
  at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:209)
  at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:292)
  at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:126)
  at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:483)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:641)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:731)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:709)
  at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:700)
  at com.esri.core.internal.io.handler.l.a(Unknown Source)
  at com.esri.client.local.LocalService.deleteService(Unknown Source)
  at com.esri.client.local.LocalService$d.run(Unknown Source)
  at com.esri.client.local.LocalService.stop(Unknown Source)
  at com.synectics.synergyii.gis.esri.runtime.PersistentLayerManager.loadImageLayers(PersistentLayerManager.java:88)
  at com.synectics.synergyii.gis.esri.runtime.RuntimeCONST.initalise(RuntimeCONST.java:108)
  at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at com.synectics.synergyii.utils.JVMUtils.exectuteStaticMethod(JVMUtils.java:108)
  at com.synectics.synergyii.utils.JVMUtils.exectuteStaticMethod(JVMUtils.java:96)
  at com.synectics.synergyii.synergygis.SynergyGISPanel.<clinit>(SynergyGISPanel.java:103)
  at java.lang.Class.forName0(Native Method)
  at java.lang.Class.forName(Unknown Source)
  at com.synectics.synergyii.gui.MapWindow.initialise(MapWindow.java:1704)
  at com.synectics.synergyii.gui.MapWindow.<init>(MapWindow.java:390)
  at com.synectics.synergyii.gui.initialise.ClientInitialise.createApplicationWindow(ClientInitialise.java:637)
  at com.synectics.synergyii.gui.initialise.ClientInitialise.logon(ClientInitialise.java:838)
  at com.synectics.synergyii.gui.initialise.PasswordEntry.actionPerformed(PasswordEntry.java:704)
  at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
  at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
  at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
  at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
  at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
  at java.awt.Component.processMouseEvent(Unknown Source)
  at javax.swing.JComponent.processMouseEvent(Unknown Source)
  at java.awt.Component.processEvent(Unknown Source)
  at java.awt.Container.processEvent(Unknown Source)
  at java.awt.Component.dispatchEventImpl(Unknown Source)
  at java.awt.Container.dispatchEventImpl(Unknown Source)
  at java.awt.Component.dispatchEvent(Unknown Source)
  at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
  at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
  at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
  at java.awt.Window.dispatchEventImpl(Unknown Source)
  at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
  at java.awt.EventQueue.access$500(Unknown Source)
  at java.awt.EventQueue$3.run(Unknown Source)
  at java.security.AccessController.doPrivileged(Native Method)
  at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
  at java.awt.EventQueue$4.run(Unknown Source)
  at java.awt.EventQueue.dispatchEvent(Unknown Source)
  at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
  at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
  at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
  at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
  at java.awt.EventDispatchThread.run(Unknown Source)
nita14
Micheal,
do you stop the service after it has been started? Use  addLocalServiceStartCompleteListener to ensure that.
Regards,
Adam
MichaelKnight
Hi Adam,
I was under the impression that start was a blocking call therefore removing the need for callbacks?
Mike
nita14
I am not 100% it will resolve your issue, but I have already seen this kind of errors....Worth trying...
Adam
