How do you move a graphic smoothly on the map?
1694
01-14-2019 04:22 PM
stevemclaughlin
I've got a car (graphic) that I get a new location every second.
Is there an easy way to move the car smoothly on the map? rather than having the car move in a jerky type motion?
thanks,
MarkBaird
If you want to update the location of a graphic you just need to apply a new geometry to it.  This sample shows the basics.
This sample shows how you can do this with a 3D symbol.
If however your jerky movements are due to your point moving a large distance then you'll need to write some interpolation code to achieve this.  You can work out interim points for a smooth motion by using Bresenham's line algorithm - Wikipedia which is pretty easy to implement if you are working in a projected coordinate system.  I'm sure there are other alternatives you could try.
Does that help?
MarkBaird
I had another flash of inspiration for working out interim points!  It would be far easier if you did this:
 - Take your old point and your new point and make them into a 2 point polyline
 - Densify the line to the number of interim points you want.  See GeometryEngine.desify
 - Crack open the geometry to extract the points which make up the densified polyline
 - Move the graphic to each interim point for a very short period of time (you'll need to experiment with this)
The above method would work with any spatial reference.  Not such an exciting solution from a software engineering point of view, but much easier.
