Create a spline with ArcGIS
1508
10-19-2022 02:42 PM
DavidLefaivre
I'm currently working on a product that need to generate spline based on a set of point. I was wondering if there was a way to generate a spline with ArcGIS, or if I absolutely need to project my point and calculate my spline from the projected point ?
Example of a spline I need to do:
Thank you
MarkBaird
Hi David,
This looks an interesting project.  We don't have a method specific to making splines, but I'm wondering if you could achieve something through the use of curve based segments.  Line or polygon segments can be made up from one of the following curve types:
 - Cubic Bezier
 - Elliptic Arc
There is a sample app here which shows how to use them.
Does this help?  If you feel there is a gap in the product, I'm always happy to consider adding something new.
Thanks
Mark
MarkBaird
Hi David,
 - Cubic Bezier
 - Elliptic Arc
Thanks
Mark
DavidLefaivre
Hi Mark,
Thank you for your fast answer. From my poor understanding on cubic spline (I'm not that good in math), a cubic spline will take a set of points and a speed and calculate the correct curve according to that data. CubicSpline seem to draw the curve I need, but I still need to make the correct calculation to determine the curve to draw.
If cubic spline is not available in Esri, than CubicBezier is a good work around for my case.
Regards,
David
