Changing the selection Color (Java Maps SDK)
1023
02-09-2023 08:02 PM
NebiSARIKAYA
How can I change the selection color of GraphicsOverlay and FeatureLayer?
2 Solutions
ColinAnderson1
You should be be able to change this through the selection properties object by using the property on GeoView and modifying the returned object.
NebiSARIKAYA
I managed to change the background color of the base map with using ArcGISMap.setBackgroundColor(Color color);
ColinAnderson1
NebiSARIKAYA
Thank you for the quick response. It worked. How can I change the background color of MapView? When I set Mapview.setBackground() with no other layers than a FeatureLayer with a ShapeFile the background goes to light gray again and I cannot change the background color. You may see the attached image.
NebiSARIKAYA
