Can't load more than 3 Local Map Service
8360
16
04-12-2013 02:29 AM
JeremieJoalland1
I face limitation with the ArcGIS Runtime 10.1.1 samples "Add Shapefile" (issue is similar with "Add Raster").
I have just changed the source code in order to load a Local Tiled Package and used my own blank MPK to load Shpaefile/Raster.
When I run the sample application, if I try to load several Shapefiles, I always have the following Exception on the 4th file.
It's like my Local Server can't handle more than 3 worker processes at the same time...
2013-04-12 12:09:24,821: INFO  rid=31  'server'  mpk3 - Request handled.
2013-04-12 12:09:24,852: INFO  rid=32  'server'  mpk - Request handled.
2013-04-12 12:09:25,055: INFO  rid=33  'server'  mpk2 - Request handled.  -> Here we see that there are 3 localmapservice already loaded
2013-04-12 12:09:29,305: INFO  rid=34  'server'  AdminWebService - POST admin/createService -> Here I just select a 4th shapefile
java.lang.NullPointerException
 at com.esri.map.Layer.setUrl(Unknown Source)
 at com.esri.map.DynamicLayer.setUrl(Unknown Source)
 at com.esri.map.DynamicLayer.<init>(Unknown Source)
 at com.esri.map.ArcGISDynamicMapServiceLayer.<init>(Unknown Source)
 at com.esri.client.samples.datasources.LocalShapefileApp.addShapefile(LocalShapefileApp.java:103)
 at com.esri.client.samples.datasources.LocalShapefileApp.access$3(LocalShapefileApp.java:73)
 at com.esri.client.samples.datasources.LocalShapefileApp$3.actionPerformed(LocalShapefileApp.java:247)
 at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
 at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
 at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
 at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
 at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
 at java.awt.Component.processMouseEvent(Component.java:6505)
 at javax.swing.JComponent.processMouseEvent(JComponent.java:3321)
 at java.awt.Component.processEvent(Component.java:6270)
 at java.awt.Container.processEvent(Container.java:2229)
 at java.awt.Component.dispatchEventImpl(Component.java:4861)
 at java.awt.Container.dispatchEventImpl(Container.java:2287)
 at java.awt.Component.dispatchEvent(Component.java:4687)
 at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
 at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
 at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
 at java.awt.Container.dispatchEventImpl(Container.java:2273)
 at java.awt.Window.dispatchEventImpl(Window.java:2719)
 at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:723)
 at java.awt.EventQueue.access$200(EventQueue.java:103)
 at java.awt.EventQueue$3.run(EventQueue.java:682)
 at java.awt.EventQueue$3.run(EventQueue.java:680)
 at java.security.AccessController.doPrivileged(Native Method)
 at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
 at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
 at java.awt.EventQueue$4.run(EventQueue.java:696)
 at java.awt.EventQueue$4.run(EventQueue.java:694)
 at java.awt.EventQueue.dispatchEvent(EventQueue.java:693)
 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
 at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
2013-04-12 12:09:35,071: INFO  rid=    ''  WebServer - Lost connection on port 50000
Stopping server   -> I've closed the application from here
2013-04-12 12:09:37,790: INFO  rid=    ''  WebServer - Lost connection on port 50000
2013-04-12 12:09:37,790: INFO  rid=35  'server'  AdminWebService - POST admin/shutdown?f=json
2013-04-12 12:09:37,790: INFO  rid=    'server'  ServerMain - Shutting down
2013-04-12 12:09:37,790: INFO  rid=    'server'  ServerMain - Terminating web services
2013-04-12 12:09:37,790: INFO  rid=    'server'  AdminWebService - Terminating service blankMap.mpk
2013-04-12 12:09:37,790: INFO  rid=    'server'  mpk_host - Terminate
2013-04-12 12:09:37,790: INFO  rid=    'server'  AdminWebService - Terminating service blankMap.mpk2
2013-04-12 12:09:37,790: INFO  rid=    'server'  mpk2_host - Terminate
2013-04-12 12:09:37,790: INFO  rid=    'server'  AdminWebService - Terminating service blankMap.mpk3
2013-04-12 12:09:37,790: INFO  rid=    'server'  mpk3_host - Terminate
2013-04-12 12:09:37,790: INFO  rid=    'server'  ServerMain - Waiting for 3 worker processes to exit. Timeout=10s.
2013-04-12 12:09:37,899: INFO  rid=    ''  WebServer - Lost connection on port 50000
2013-04-12 12:09:37,899: INFO  rid=    'server'  ServerMain - Worker processes exited.
2013-04-12 12:09:37,899: INFO  rid=    'server'  ServerMain - Deleting data directory C:/Windows/Temp/arcgisruntime_6452
2013-04-12 12:09:37,899: INFO  rid=    'server'  ServerMain - 10 filesystem object(s) removed.
2013-04-12 12:09:37,899: INFO  rid=    'server'  ServerMain - Server process exiting.
Local server exited, code: 0
Exception occurs on addShapefile(LocalShapefileApp.java:103), and corresponds to :
// set up a local dynamic layer
        final ArcGISDynamicMapServiceLayer localDynamicLayer = new ArcGISDynamicMapServiceLayer(
                localMapService.getUrlMapService());
I've checked for Local Server parameters in the runtime tool "Local Server Utility 10.1.1", but nothing there...
Any ideas why I have limitations for 3 local map services ???
EliseAcheson1
That was what the first part of my post was about.
When I use USCitiesStates.mpk for example from the sample data that comes with the SDK, I can add 3 shapefiles as it has 3 sublayers. If I use the mpk_blank, I can add one at a time.
Note that the code I attached has a couple of build errors against 10.1.1 jars, from imports that have changed packages. A simple remove/re-import solves that but just to mention it.
~elise
CarlosColón-Maldonado
I'm seeing similar behavior loading NGA Raster Product Format (RPF) raster types. The occurrence is random based on what is being loaded: Common Imagery Base (CIB) averages on the fifth attempt, Global Navigation Chart (GNC) goes no more than three attempts, and Jet Navigation Chart (JNC) takes no more than 4 files. I'm enclosing the Runtime local server utility log and eclipse console log files when trying CIB types.
The symptom is overall identical based on log entry "WebServer - Lost connection on port 50000."
MarkBaird
Tried this out today and it's looking like it might be a bug.
We're looking at it... however we think we've got a workaround which we're testing out so all it not lost.  Watch this space.
Mark
MarkBaird
Looked at this some more.
I've found that there doesn't appear to be a limitation to the number of local services you can run (obviously I've not gone mad adding them as you'd just run out of memory).
I think the problem here appears to be around using the same MPK file multiple times.  I modified the sample code so that is used a dedicated MPK file for each instance of the local server and I was able to add around 12 shapefiles without issue.
The other potiential option is to add multiple shape files to a single instance of a local server.
Mark
JeremieJoalland1
Thanks Mark. I was able to load lot more shapefiles and raster using a different MPK for each new local map service... so I agree, the limitation seems to appear when using the same MPK file multiple times.
However it's not good news for me, as my application should stay open on the number of shapefile/raster the user can load (even if performance could be impacted), so I will have to copy my MPK template file before each time I want to create a new local map service... not so great !
So I'm definitly interested in your second idea :
- could you provide a sample code for this ? (multiple shp to a single instance of "local map service" ?)
- but will I still be able to manage layer order the same way ? (user can change layer order at any time in my app)
       -> if exemple I have 1 TPK, 1 GraphicsLayer and 2 Shapefiles added to same MPK instance, could I manage order like  0-TPK  1-SHP n°1  2-GraphicsLayer  3-SHP n°2 ?
The other potential option is to add multiple shape files to a single instance of a local server.
Ditto! I'll be watching for some sample code. The multiple sets of data to be loaded at once (RPF), I plan to keep as a representation of a single raster layer, so I am not as concerned with the layer ordering of raster file of a set since they are related. Shape files, though, can be of concern.
EliseAcheson1
For multiple shapefiles to one local map service, you need to have them in the same directory and then when you create your dynamic map service layer, for each sub layer you can update the dynamic layer infos to point to your shapefile datasource. The limitation here is in your available sublayers. With 3 sublayers you can add 3 shapefiles in one go, etc.
The shapefiles at this point are like sublayers of an ArcGISDynamicMapServiceLayer, so they would move as a group and not separately.
I'll attach a modified version of the add shapefile sample that has the multiple file selection enabled on the JFileChooser and corresponding modifications to loop through each file selected.
~elise
JeremieJoalland1
When using your sample code, after selecting multiple shapefiles from same folder, they seem all to be added correctly as sub-layers to the ArcGISDynamicMapServiceLayer, through DynamicLayerInfoCollection...
😞 But each time only one (the first one) shapefile is displayed on the map !!
After the for {} which add all sub-layers and just before the setDynamicLayerInfos(dynamicLayerInfos), if I check the size of the DynamicLayerInfoCollection variable, result is 1 (should it not be 3 if I added 3 Shpaefiles ?) :
- dynamicLayerInfos.size() return "1" !
- dynamicLayerInfos.getVisibleList().size() return "1" !
Do you have this behavior ?
EliseAcheson1
~elise
JeremieJoalland1
ok, sorry I didn't undertand this sub-layers capacities from the blank mpk.
much clearer now 🙂
don't worry, your code is easy to use once we redo the import and change the TPK/MPK used.
Thanks for your help and code sample.
