please help me! how to show infoTemplate in method  function showResults(featureSet)
4140
09-13-2014 03:13 AM
lasinh
this is my code. i clicked symbol and show infoTemplate . i want call function showResults(featureSet) show infoTemplate
function showResults(featureSet) {
                  //remove all graphics on the maps graphics layer
                  myMap.graphics.clear();
                  var resultFeatures = featureSet.features;
                  //Loop through each feature returned
                  for (var i = 0, il = resultFeatures.length; i < il; i++) {
                      //Get the current feature from the featureSet.
                      //Feature is a graphic
                      var attr = resultFeatures.attributes;
                      var title = attr.TEN;
                      var content = "Field ID : " + attr.OBJECTID
                    + "<br />Tên: " + attr.TEN
                    + "<br />Địa chỉ : " + attr.TEN
                      //initialize InfoTemplate
                      infoTemplate = new InfoTemplate("Kết quả tìm kiếm:", content);
//                      myMap.infoWindow.setTitle(title);
//                      myMap.infoWindow.setContent(content);
//                      myMap.infoWindow.show(resultFeatures[0].geometry);
                     var graphic = resultFeatures;
                      graphic.setSymbol(symbol1);
                   //Set the infoTemplate.
                     graphic.setInfoTemplate(infoTemplate);
                      //                      //Add graphic to the map graphics layer.
                      //                      myMap.graphics.add(graphic);
                      myMap.centerAndZoom(resultFeatures[0].geometry, 7);
RiyasDeen
Hi Ia,
If your geometry is expected to points, add below lines after your myMap.centerAndZoom(resultFeatures[0].geometry, 7);
myMap.infoWindow.setFeatures([resultFeatures[0]]);          // Get first feature and add it into an array.
myMap.infoWindow.show(resultFeatures[0].geometry);     // Show info window at the location of your first feature.
This should do the trick.
DanPatterson_Retired
Can you provide a Place or Space where you would like this redirected.  Also, providing some tags for your post in the tags section would facilitate getting an answer
lasinh
my problem is how to show symbol and infotemplate  that no click symbol.
RiyasDeen
Hi Ia,
lasinh
Re: please help me! how to show infoTemplate in method  function showResults(featureSet)
Riyas, it works exactly as I expected.I hope these help you later. thanks Riyas...
