Basic CRUD operations?
4715
8
07-31-2014 08:12 AM
KeithWeber1
I am trying to find out if I can accomplish basic CRUD operations on an Enterprise geodatabase using ArcGIS Runtime SDK for Java or if I need to use ArcObjects.
I am looking at developing a service that will run on my server that is going to monitor a few folders. As various files are added to these folders, my service needs to parse these files and insert/update/delete records in an enterprise geodatabase. Can I implement this using the runtime sdk? Thanks in advance for any feedback!
-Keith
EricBader
Hi Keith:
Excellent question, thank you for asking!
The Runtime SDKs are used for building client apps that do not run behind web or application servers. As a matter of fact, (sadly, hopefully someday this will change) using the Runtime APIs in a Server (multi-user) environment is a violation of the Runtime license agreement.
It sounds like the recommendation for your use case would be to build and deploy a Server Object Extension (SOE) built with ArcObjects and deployed to ArcGIS for Server.
I hope this is helpful!
EricBader
Hi Keith:
KeithWeber1
Eric,
Thanks for the quick feedback! This is just the type of advice I was looking for. Thanks!
CristianCerb
Hi Eric,
Is there such a SOE sample anywhere? I mean, based on a feature service...
Thank you.
EricBader
Hi Cristian,
Here is a simple example of building an SOE that works with Feature Services....
ArcObjects Help for Java developers
There are a few others here as well. I hope this helps!
CristianCerb
Thank you very much, Eric. Unfortunately I get a page doesn’t exist when going to that link:
CristianCerb
More precisely, when I click View Source I get to that page I sent just before…
CristianCerb
Ok, I managed to access source code using the Download source code link. Thanks.
EricBader
Crazy GeoNet.
Sorry for the hassles.
For any future reference, you could look here, and browse to 'Samples-->Server Object Extensions':
http://http://resources.arcgis.com/en/help/arcobjects-java/concepts/engine
