I have a polyline that when I come to a curve, the lines do not meet. Is there a way to fix this?
how was the line created? did you use 'copy parallel' at some point
you can try
Extend Line—Help | ArcGIS Desktop
What product is rendering that line? ArcMap, ArcGIS Pro, a web application?
Thank you for responding. It’s in ArcMap. It’s a single line that was copied from one shapefile and pasted into a new shapefile. Then I represent that single line with 3 lines in which I have changed the spaces in between the lines. Instead of forming an elbow when the line turns, it breaks the line. I have figured out a work around but it’s very time consuming. I tried the copy parallel and it works beautifully...I need each line however to be a different color.
This is how the line looks at direction changes:
This is how I want it to look:
Thanks again for responding!
I'f I'm understanding you correctly, it's easy peasy!
As long as the actual feature lines are touching end to end, you can just setup symbology to allow the lines to look as you've drawn in the last picture, you can control the way lines join and connect using some advanced configuration options with the Symbol Property Editor.
Double-click on the layer in the Table of Contents to get to the symbology dialog window, then click Edit Symbol:
In this dialog, you'll note that each piece of a line is shown, click on one part of the symbol, then select how the line Caps and Line Joins are displayed.
This should give you the granular control you need to achieve what you're attempting to do.
I tried changing the line to Square and Miter. It helped some on the curve but not in other areas.
An improvement here
Not so much here
Signed in members can post, follow updates, and more. New here? Register a free account.
