Authorizing ESRI software in DMZ environment
1865
04-02-2019 08:59 AM
OscarBarrera1
I have deployed an ArcGIS server in a DMZ environment and I am having problems authorizing the software using the software authorization wizard. The wizard goes thru four steps:
1. Connecting to ESRI.
2. Uploading the wizard-collected information
3. Authorizing the software.
4. Sending back software authorization file.
The process fails in step four:
I use the same method to authorize software for deployments not in the DMZ without a problem.
I am assuming that the perimeter firewall at the DMZ is blocking the incoming software authorization file.
Does anyone know what ports are used during the software authorization process?
by Anonymous User
Not applicable
The closest thing I found to that was how to configure the ArcGIS License Manager to work through a firewall. I'll place a link to that in the following:
I hope this helps.
JacobBoyle412
If you can't authorize due to security settings in your DMZ, you'll need to select I have installed my software and need to authorize it.  Then you'll select: Authorize at Esri's website or by email to receive your authorization file.
https://enterprise.arcgis.com/en/server/latest/install/windows/authorize-arcgis-server.htm
This will allow you to authorize the server.
The other option would be to work with your IT department and white-list Esri's domains in the DMZ.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
