Hi Sandeep
I have tried all sorts of things to try to get it to work including a standalone vanilla anaconda environment. But in Windows it gives the below errors.
conda install -c esri arcgis_learn=1.9.1 python=3.8
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: |
Found conflicts! Looking for incompatible packages.
This can take several minutes. Press CTRL-C to abort.
failed
UnsatisfiableError: The following specifications were found to be incompatible with each other:
Output in format: Requested package -> Available versions
Package python conflicts for:
arcgis_learn=1.9.1 -> boost=1.73 -> python[version='>=2.7,<2.8.0a0|>=3.9,<3.10.0a0|>=3.9,<3.10|>=3.8,<3.9|>=3.7,<3.8|>=3.6,<3.7|>=3.6']
arcgis_learn=1.9.1 -> python[version='>=3.6,<3.7.0a0|>=3.8,<3.9.0a0|>=3.7,<3.8.0a0']
python=3.8
I have also tried in Linux, the install gets further but then starts coming up with pages of errors such as
ClobberError: This transaction has incompatible packages due to a shared path.
packages: esri/linux-64::torch-cluster-1.5.9-py38_torch18.0_cuda11.1_2, esri/linux-64::torch-scatter-2.0.7-py38_torch18.0_cuda11.1_2, esri/linux-64::torch-spline-conv-1.2.1-py38_torch18.0_cuda11.1_2, esri/linux-64::torch-sparse-0.6.10-py38_torch18.0_cuda11.1_1
path: 'lib/python3.8/site-packages/test/utils.py'
Any ideas?
Thanks
Tim
