Check a rasters current tile size
1915
07-07-2016 09:12 AM
RachelAlbritton
I was given a raster image, GRID format. I'm trying to figure out what the current tile size is. The only reference I can find in ESRI docs is the environment setting/raster storage. But if I look here it just shows the default value of 128*128 and only applies if I do any analysis. I also looked in raster statistics, and its not listed as a property. How do I find what it currently is?
DanPatterson_Retired
If you right-click on a raster, in this case an esri grid, you then select properties.  From there, you can determine the raster extent and the cell size, which will cover what you are looking for
RachelAlbritton
Thanks Dan, but thats not what I need.
This imagery will be loaded into an enterprise Database and I am currently trying to calculate the ArcSDE transport buffer size necessary to do this successfully. To do this, I need to know the tile size (http://resources.arcgis.com/en/help/main/10.1/index.html#//009t0000006m000000). The extent values and cell size will not help me in this case.
