If you have 10.3, then see the link Kishor posted. I only briefly tested this but at 10.3, I was able to add a single band from an HDF file doing the following in the Add Rasters tool:
1. Select the HDF raster type.
2. Specify your HDF dataset.
3. Open the Raster Type Properties dialog (button with hand).
4. Select the Variables tab and check the band I wanted.
This procedure worked for adding just one of the subdatasets but I only tested this with a single HDF file I had available. It also looks like at 10.3 that you may be able to add the entire HDF file and just work with the specific data you need per the resource Kishor provided.
Prior to 10.3, you will need to use the Extract Subdataset tool to extract the band you want from the HDF files before adding them to a mosaic dataset.
