After create a Mosaic, some photos are whiter than the rest
2874
03-26-2015 01:31 PM
DiegoLlamas
Hello,
I have been trying to create a mosaic conform with several photos. for some reason when I upload the photos some of them are whiter as you can see in this photo.
If you compare this with the original
I tried calculating statistics and overview but always the photo result lighter. this is the fist time i got this problem, i have done several mosaics and they are ok.
Any idea how can I fix this?
thanks for your help!
Diego Llamas
JayantaPoddar
MVP Esteemed Contributor
DanPatterson_Retired
If using Mosaic  did you check out the options in mosaic colormap mode?
PROBERT68
Try to change it to either MAX or blend  that should do it
