Struggling to convert a raster file into CAD
5204
02-14-2018 08:31 AM
CameronRae
I am a student working on a school project that is unfamiliar with ArcGIS software.  I need to complete a grading plan on a site, and for this I need to move a raster with elevation data into AutoCAD.  The current file type is OVR and I need to convert this file into AutoCAD without losing any of the elevation data.  Any help would be greatly appreciated.
Tags (1)
DanPatterson_Retired
Raster to Polyline .... but absolutely no guarantee that the attributes will be carried forward since I suspect the *.ovr file is merely a picture and you might have to ascribe the numeric values to any resultant polylines after the fact.  I wouldn't even be able to suggest a workflow that was simple if that was the case
CodyBenkelman
Cameron
the *.ovr file is a reduced resolution view ("overview" or "pyramid") of an original file - you may want to double check in the folder (if you got it?) to see if there's a *.tif or other file with the same basename.  The *.ovr file will be smaller in size but not the full resolution of the original - not sure if that matters (but I wonder why you were given the *.ovr instead of the original).
But that is somewhat academic, hoping to inform you.  For a quick answer to your immediate need:  try making a copy and changing the extension to *.tif.  The *.ovr format is fundamentally tiff inside and this may simply work, although I expect the *.ovr will contain multiple resolutions within it, and I don't know for certain if Autocad will handle it properly.
If the above does not work and you have ArcGIS, try reading the *.ovr --> renamed .tif by loading it into the map.  If it appears black, apply a stretch to see if you have good elevation values.  Let us know if any of these instructions are too sparse.  also let us know if you have ArcMap or ArcGIS Pro, and what version.  Sorry I won't be any help with AutoCAD.
Cody B.
XanderBakker
Esri Esteemed Contributor
I have done this for a project some time ago (20+ years ago!). What we did was create a hillshade and mix it with the elevation colors and export as TIF and use it as background in AutoCAD.
Now, before you go there, do you really need to do this in CAD? Remember that you can bring your CAD data into ArcGIS and create some beautiful cartography in ArcGIS too.
