Error loading images over STAC connection in ArcGIS Pro
1806
01-15-2024 03:28 PM
tempLeidyGarcía
Hello community, I have been testing the STAC connection for ArcGIS Pro, showing that results from various sources such as Sentinel, Landsat, among others, are not added to the map. Every time I try to add them I get an "Unknown Error" as shown in the screenshot.
Please could you guide me.
xingchenc
@tempLeidyGarcía
Hi Leidy, I believe I have encountered similar problem, please see my post for the solution(Solved: Re: Microsoft Planetary Computer STAC - unable to ... - Esri Community).
The key is to create a clould storage connection file and use it when creating STAC connection. You can download directly from here(arcgis-for-mpc/AMPC_Resources/ACS_Files at main · Esri/arcgis-for-mpc · GitHub) or you can follow the steps in the post to create one for yourself.
Hope this helps.
xingchenc
@tempLeidyGarcía
Hope this helps.
Youssef-Harby
Hi @tempLeidyGarcía and @xingchenc, I made a small tool that might be helpful here
It’s a Go-based proxy that handles the SAS token logic and CORS issues when using Microsoft Planetary Computer STAC with ArcGIS Pro. You just point ArcGIS to
http://localhost:8080/api/stac/v1/
and skip the manual ACS setup.
I put together a short tutorial (under 3 mins): https://youtu.be/CeIfDvK1F2U
Code repo: https://github.com/Youssef-Harby/ms-stac-proxy
Let me know if you try it out!
https://www.linkedin.com/in/youssef-harby/
