Configure DataStore in HA deployment
1187
03-19-2025 09:59 AM
CarstenHogertz
Hi community,
i've got a High Available ArcGIS Enterprise deployment. There are two VMs, both with an ArcGIS Server and DataStore installation. The AGS are active/active together in site. Now I registered the DS on the first VM with <ipVM1>:6443/arcgis. Everything worked fine.
My question is for the DS on the second VM. Should I use <ipVM1>:6443/arcgis or <ipVM2>:6443/arcgis?
Thanks for your help.
Tags (1)
ArchitSrivastava
Hello @CarstenHogertz ,
As per my understanding, we should use "<ipVM1>:6443/arcgis" as utilized for registering the first ArcGIS Data Store machine as it is recommended in the documentation.
For more details:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/add-standby-machine.htm#ESRI_SECTI...
Hope it helps!
Marc_Graham
Hi @CarstenHogertz
I'm not sure that your deployment pattern is optimal. I recommend you read some of the documentation like https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-highly-available-system....
You have not provided much detail on your deployment.  Do you have arcgis portal on each machine as well? What data stores are you referring to? Just relational?  Each different type of data store has different deployment patterns and requirements.
CarstenHogertz
Hi @Marc_Graham,
The environment comprises four virtual machines.
VM1 & VM2 contain AGS & relational DS, VM3 & VM4 the portal. Everything is on high availability. The AGS are registered as hosted servers in the portal. The web adapters also run on dedicated VMs.
The DS backup runs on a shared network folder. Both DS backup directories point to the same folder on the shared network.
What would be your suggestion for configuring the DS?
JakeSkinner
Esri Esteemed Contributor
Hi @CarstenHogertz, as @ArchitSrivastava mentioned, you can configure the second data store with VM1.  This will configure the second data store as the standby data store.  In the event the primary data store on VM1 is broken, it will fail over to the standby data store on VM2.
