Clean Install Object Store Cluster 11.5 Unhealthy
854
08-22-2025 03:53 AM
Oiligriv
I'm performing a clean installation of ArcGIS Datastore Object Store on dedicated virtual machines to then migrate the tile caches.
The setup went smoothly, and the service user is the same for all three VMs.
I performed the configuration via the web and via command line, but the result is always the same.
Via the web on port 2443/arcgis/datastore, I noticed that the number of VMs in the Cluster is counted correctly.
When I validate via ArcGIS Server Manager, it loops. But if I validate via the Server Rest Admin, I see the following error.
I'm currently very hesitant to launch the 3D cache migration.
Is this behavior normal in Rest Admin?
"datastore.name": "oz_hct7a6e",
"datastore.isConfigured": "true",
"datastore.isRegistered": "true",
"deploymentMode": "cluster",
"finalized": true,
"machines": [
"machine.overallhealth": "Transitional",
"platform": "Windows",
"name": "PVW-AGOSGEO-AS1.CED.******",
"role": "CLUSTER_MEMBER",
"heapSize": "5246MB",
"healthcheck.enable": "false",
"status": "Starting",
"isSCMHealthy": true,
"isOMHealthy": false,
"isDataNodeHealthy": false,
"s3gStatus": {
"s3gHttpsPort": 29879,
"isS3GHealthy": false
"machine.overallhealth": "Failed",
"name": "PVW-AGOSGEO-AS2.CED.******",
"status": "StartFailed",
"isSCMHealthy": false,
"s3gStatus": {
"machine.overallhealth": "Unknown",
"name": "PVW-AGOSGEO-AS3.CED.******",
"status": "Configured",
"s3gStatus": {
"messages": [{"msg": "'PVW-AGOSGEO-AS3.CED.******' is not reachable. Ensure that the machine is powered on and its hostname is accessible."}]
"datastore.overallhealth": "Unhealthy",
"status": "success"
Priya_Das
Hi @Oiligriv
Are you trying to remove the Object datastore from your Environment? If so, I believe we wont be able to remove Object Datastore from ArcGIS Server Manager.
We need to unregister the Object Datastore from Server Admin endpoint.
Login to Server Admin>Home > data > items > cloudStores
Copy the Child item (Image 1)
Then to Unregister the object datastore: Home>Data>unregisterItem
In Item path: Paste the item path (Image 2)
Once completed check if the object datastore still exists or not. You can run describe datastore as well.
Before running this take a VM snapshot for backup.
Oiligriv
Hi Priya97317
To unregister the ArcGIS Datastore Object Store, I can easily do it using the unregisterdatastore.bat tool.
The object store was just installed and I'm registering it for the first time, but before migrating, I'd like to make sure the validation is OK.
Thanks for the information, but that's not my problem.
Virgilio
SimonSchütte_ct
MVP Regular Contributor
Did you configure the objects stores one after the other? Installing them at the same time will cause issues. If you have new machines and no data stored, you can unregister the object store and clear the datastorecontent directory, than you will be able to cleanly register the object store with the cluster (new id will be generated).
There also may be a bug in the Server Manager validation, Object Store validation always fails for me but when directly validating in the server admin it validates successfully. When I open the dev console before starting the object store validation in server manager I see the validation call and it is using a proxy parameter for some reason (no, not set by me).
