Hello,
During ArcGIS 10.2 caching tiles I encountered with some errors but could not find any solution in web. What I found in web as solution was to make caching as foreground process (instead of background process) by clicking Geoprocessing > Geoprocessing Options on the Standard toolbar and uncheck background option. I did so, but errors continue flowing although caching process continues.
If I choose background cache process instead of foreground cache then cahcing halts.
What should I do?
I am getting following errors during cahcing (caching process continues):
Failed to cache extent: 2974329,588527 4931117,511619 3052577,218922 5009365,142013 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 2974329,588527 5009389,028585 3052577,218922 5087636,658980 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Output failure, error string = Unable to construct the map service instance.
Failed to cache extent: 2974329,588527 4618031,443754 3052577,218922 4696279,074149 at scale 9027.9774109999998 Xml Parsing failed.
Reason:XML document must have a top level element.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4539759,926788 3052577,218922 4618007,557183 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 2974329,588527 4383216,892856 3052577,218922 4461464,523251 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4304945,375890 3052577,218922 4383193,006285 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4226673,858924 3052577,218922 4304921,489319 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 2974329,588527 4163969,476778 3052577,218922 4226649,972353 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5165932,062517 3130848,735888 5176676,972045 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5087660,545551 3130848,735888 5165908,175946 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3052601,105493 5009389,028585 3130848,735888 5087636,658980 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4931117,511619 3130848,735888 5009365,142013 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4852845,994653 3130848,735888 4931093,625047 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4774574,477687 3130848,735888 4852822,108081 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4696302,960721 3130848,735888 4774550,591115 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4618031,443754 3130848,735888 4696279,074149 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4539759,926788 3130848,735888 4618007,557183 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4461488,409822 3130848,735888 4539736,040217 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4383216,892856 3130848,735888 4461464,523251 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4304945,375890 3130848,735888 4383193,006285 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4226673,858924 3130848,735888 4304921,489319 at scale 9027.9774109999998
Failed to cache extent: 3052601,105493 4163969,476778 3130848,735888 4226649,972353 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5165932,062517 3209120,252854 5176676,972045 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5087660,545551 3209120,252854 5165908,175946 at scale 9027.9774109999998
Failed to cache extent: 3130872,622459 5009389,028585 3209120,252854 5087636,658980 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3130872,622459 4852845,994653 3209120,252854 4931093,625047 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4774574,477687 3209120,252854 4852822,108081 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4696302,960721 3209120,252854 4774550,591115 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3130872,622459 4539759,926788 3209120,252854 4618007,557183 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4383216,892856 3209120,252854 4461464,523251 at scale 9027.9774109999998 Xml Parsing failed.
Reason:Not enough storage is available to complete this operation.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4304945,375890 3209120,252854 4383193,006285 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3130872,622459 4226673,858924 3209120,252854 4304921,489319 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:41
Source://///////////////////////////////////////.
Failed to cache extent: 3130872,622459 4163969,476778 3209120,252854 4226649,972353 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:7
Source:GRoaWVx.
Failed to cache extent: 3130872,622459 4461488,409822 3209120,252854 4539736,040217 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 5165932,062517 3287391,769820 5176676,972045 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 5009389,028585 3287391,769820 5087636,658980 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4931117,511619 3287391,769820 5009365,142013 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 5087660,545551 3287391,769820 5165908,175946 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 4852845,994653 3287391,769820 4931093,625047 at scale 9027.9774109999998
Failed to cache extent: 3209144,139425 4696302,960721 3287391,769820 4774550,591115 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4774574,477687 3287391,769820 4852822,108081 at scale 9027.9774109999998 ERROR 999998: Unexpected Error.
Failed to cache extent: 3209144,139425 4618031,443754 3287391,769820 4696279,074149 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
Failed to cache extent: 3209144,139425 4461488,409822 3287391,769820 4539736,040217 at scale 9027.9774109999998 Xml Parsing failed.
Linepos:0
Source:(null).
I would first address the messages in the errors:
Xml Parsing failed.
Have you checked that the conf.xml file is valid under the cache directory?
Xml Parsing failed.
Have you made sure that there's enough space on the directory the arcgiscache folder is stored?
1. Have you checked that the conf.xml file is valid under the cache directory?
conf.xml file is well-formed but can not see if it is valid. But only error is at Level 16 :
<Resolution>4.7773142679493699</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>16</LevelID><Scale>9027.9774109999998</Scale>
There is no error at other layer I think there is some deficiency in Layer 16 ?
2 .Have you made sure that there's enough space on the directory the arcgiscache folder is stored?
Yes Im sure than 1 TB is free there in 2 days only 30 GB is used and it says 40 hours left and I have made an estimated required disk space of 140 GB < 1 TB
Below is conf.xml:
<?xml version="1.0" encoding="utf-8" ?><CacheInfo xsi:type='typens:CacheInfo' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:xs='http://www.w3.org/2001/XMLSchema' xmlns:typens='http://www.esri.com/schemas/ArcGIS/10.1'><TileCacheInfo xsi:type='typens:TileCacheInfo'><SpatialReference xsi:type='typens:ProjectedCoordinateSystem'><WKT>PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0],AUTHORITY["EPSG",3857]]</WKT><XOrigin>-20037700</XOrigin><YOrigin>-30241100</YOrigin><XYScale>148923141.92838538</XYScale><ZOrigin>-100000</ZOrigin><ZScale>10000</ZScale><MOrigin>-100000</MOrigin><MScale>10000</MScale><XYTolerance>0.001</XYTolerance><ZTolerance>0.001</ZTolerance><MTolerance>0.001</MTolerance><HighPrecision>true</HighPrecision><WKID>102100</WKID><LatestWKID>3857</LatestWKID></SpatialReference><TileOrigin xsi:type='typens:PointN'><X>-20037508.342787001</X><Y>20037508.342787001</Y></TileOrigin><TileCols>256</TileCols><TileRows>256</TileRows><DPI>96</DPI><PreciseDPI>96</PreciseDPI><LODInfos xsi:type='typens:ArrayOfLODInfo'><LODInfo xsi:type='typens:LODInfo'><LevelID>0</LevelID><Scale>591657527.591555</Scale><Resolution>156543.03392800014</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>1</LevelID><Scale>295828763.79577702</Scale><Resolution>78271.516963999937</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>2</LevelID><Scale>147914381.89788899</Scale><Resolution>39135.758482000092</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>3</LevelID><Scale>73957190.948944002</Scale><Resolution>19567.879240999919</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>4</LevelID><Scale>36978595.474472001</Scale><Resolution>9783.9396204999593</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>5</LevelID><Scale>18489297.737236001</Scale><Resolution>4891.9698102499797</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>6</LevelID><Scale>9244648.8686180003</Scale><Resolution>2445.9849051249898</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>7</LevelID><Scale>4622324.4343090001</Scale><Resolution>1222.9924525624949</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>8</LevelID><Scale>2311162.2171550002</Scale><Resolution>611.49622628137968</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>9</LevelID><Scale>1155581.108577</Scale><Resolution>305.74811314055756</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>10</LevelID><Scale>577790.55428899999</Scale><Resolution>152.87405657041106</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>11</LevelID><Scale>288895.27714399999</Scale><Resolution>76.437028285073239</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>12</LevelID><Scale>144447.638572</Scale><Resolution>38.21851414253662</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>13</LevelID><Scale>72223.819285999998</Scale><Resolution>19.10925707126831</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>14</LevelID><Scale>36111.909642999999</Scale><Resolution>9.5546285356341549</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>15</LevelID><Scale>18055.954822</Scale><Resolution>4.7773142679493699</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>16</LevelID><Scale>9027.9774109999998</Scale><Resolution>2.3886571339746849</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>17</LevelID><Scale>4513.9887049999998</Scale><Resolution>1.1943285668550503</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>18</LevelID><Scale>2256.994353</Scale><Resolution>0.59716428355981721</Resolution></LODInfo><LODInfo xsi:type='typens:LODInfo'><LevelID>19</LevelID><Scale>1128.4971760000001</Scale><Resolution>0.29858214164761665</Resolution></LODInfo></LODInfos></TileCacheInfo><TileImageInfo xsi:type='typens:TileImageInfo'><CacheTileFormat>PNG</CacheTileFormat><CompressionQuality>0</CompressionQuality><Antialiasing>false</Antialiasing></TileImageInfo><CacheStorageInfo xsi:type='typens:CacheStorageInfo'><StorageFormat>esriMapCacheStorageModeCompact</StorageFormat><PacketSize>128</PacketSize></CacheStorageInfo></CacheInfo>
