How do I link county names with a location?
2420
6
07-02-2019 09:05 AM
BlakeAlbright
Before I can ask my question I will provide some background.  I am looking to map the number of medical doctors, primary doctors, otolaryngologists, and radiation oncologists for each county across the US.  I split the large database I have into each of those categories.  When I added the layers, several counties in CO and various ones on the east coast did not show up.  I am unsure how they are missing as they are clearly included in the .csv file I used to add the layers.  The missing counties are also in the layer table but not visible on the map.  How can I get the 30ish missing counties to display with the other 3200??
EileenAllen
I suspect you have a typo for each of those counties; most likely an extra space either before or after the FIPS (or whatever you are using for the key).
forestknutsen1
Are you displaying xy events from the csv?
BlakeAlbright
No the csv has only the column of number of physicians, the county name (county, St) and the cooresponding FIPS code.
forestknutsen1
So, are you joining the csv to a feature class with counties?
EileenAllen
forestknutsen1
Yep, that is what I was thinking as well.
BlakeAlbright
Yes, I eventually joined features with counties and the 30 missing counties still fail to show up. Today I mapped one of the missing counties (mineral county, CO) and it displayed in mineral County Nevada when using the name as the location key. I tried to use Fips codes again but I am not sure which item to chose from the drop down when I am importing the layer.
Get Outlook for iOS<https://aka.ms/o0ukef>
