ArcGIS Pro V 3.5.1 ST_Geometry version supported
161
a week ago
RachelMba1
Hello. I am working on installing PostgreSQL and successfully using it on my ArcGIS Pro. I am using ArcGIS Pro version 3.5.1, and I also downloaded the ArcGIS Pro ST_geometry Library (PostgreSQL). The challenge I am encountering is that I do not know the version of ST_Geometry supported by ArcGIS Pro 3.5.1. I will need this information so that I can copy that .dll file to my Postgres V 15.13 file.
I will appreciate any clues to help.
DanPatterson
MVP Esteemed Contributor
Upgrade the ST_Geometry type in a PostgreSQL database—ArcGIS Pro | Documentation
says
Download a new version of the st_geometry library from My Esri.
I don't use it, so you will have to check
... sort of retired...
George_Thompson
Esri Notable Contributor
Make sure you select the folder that says "15" then the OS of the PostgreSQL instance is installed on (Windows / Linux).
It is not needed if using RDS or similar instance in cloud
--- George T.
syedinzamam
You're close! For ArcGIS Pro 3.5.1 with PostgreSQL 15.13, the supported ST_Geometry version is 5.0.0. You’ll find the .dll in the DatabaseSupport\PostgreSQL folder inside your ArcGIS Pro install directory — just match it to your Postgres version.
Also, I’ve shared some useful GIS resources (including free tools) here if you're interested:
https://cartogeek.com/free-gis-software/
Hope that helps!
